Advise on DME Removal
I think you have a tip so you will see a second control unit behind the carpet.
Ok, removed the DME today or what I thought was the DME. There're 2 units, 1 with part number 986 618 240 01 and the other starting with 996 *** (also marked Cartronic). I removed the one on the right. It has just 1 single connector to it for all the cables. The other one has multiple connectors. Both are labelled Bosch.
My question is, did I remove the correct unit and not the Tiptronic one....
Have attached 2 pics....
Pllleeeeaasse tell me I removed the correct unit :) I also disconnected the batt before unplugging the DME.
PS : I'm sending it to GIAC finally....
