Multi function display... Option erased
It is your battery. One of them is going dead, most likely the front. I started by charging both from the fron using C-Tek....nothing. I then removed the rear and charged it with regular charger, still nothing. Took the front out and connected it my charger and it read 13v so I just put it back in and BAM! it was back. I am figuring that it just needed a reset.
Update.....
Yesterday i wanted to open the car by using remote key. Not working. I opend the car by turning in the key and open door manual.
On the display " start engine" in red letters ... Which i never saw before.
I started the truck without problems. I stay in the car, engine running, park position. Checking the display and guess what.... The option "comfort settings" appeared on the display.
I dont know what to say. More and more this car is like a miracle. Doing wyrd things which i cant explain.
But for the moment this display story looks solved. I believe it has something to do with the memory settings of my drivers seat. Because i remember the display story started when i used the memory function of my seat first time last week.
Thank you for all your input.
By the way.... Batterie i guess isnt the problem. I changed it 6 month ago for a new one
