  • ×   Pasted as rich text.   Paste as plain text instead
  • Similar Content
    • By Pkcayenne
      Hi all I’ve been fighting with the cayenne again
      let’s me put the key in and turn it then I get steering fault as attached any ideas of a way around this or a reset thanks car won’t start
    • By 318touring
      X-posting from other forums as this seems to be a rare issue?
      Car is 2010, C2, PDK
      Has anyone had this issue?
      I have read a post or two where people were just leaving things be.
      Would appreciate getting any feedback on what could be the cause. I have checked the power steering fluid, and it was full.
      The video is of the rack itself.
    • By Pkcayenne
      Hi cayenne 04 CTT weirdness the below list of functions was intermittent now nothing works
      buttons on steering wheel
      tiptromic button on steering wheel
      wipers
      cruise control
      pin out adjustment
      all functionality on the steering wheel except it steers perfectly all fuses are good errors as attached any ideas was intermittent
    • By nwGTS
      I am wiring indicators, horn and brights (for flash) to an OMP steering wheel hub with buttons to my 2012 997.2 GTS.  I need the wire diagram of the indicators and brights on the steering column so I know which wires to tap (horn is done already).
      Does anyone have this diagram or know where I can find it?
      Edit: Looks like i need the wire diagram for these two specific parts,1 and 3 in the embedded image.  3 is the switch would probably be the one I want.  1 is the control unit and would be helpful to have but redundant if I have 3 and I probably need 3 anyway in order to test any wiring done on 1.
    • By 2lflat4
      The vehicle is a 2005 997 Carrera 3.6. I cannot find the part #'s for the 3 power steering pump mounting bolts. They are exposed after removing the power steering pump pulley. In the attached picture you will see 3 holes in an upside down U shape behind the triangular pulley mount. I tried my local dealer without any luck.
