What hyd oil may be used in the power steering in a 2004 996TT? Seems my mechanic did not check and even at temp. fluid does not show on the dip stick.
Thanks in advance for your help.
Randy
if you don't have any sign of fluid in the steering reservoir you better looked at the clutch reservoir if it is not overfilled. If it is you've got a slave problem...
