I was thinking about putting some nice black oversize wheels and tires on my Cayenne. Is 275/45/20 okay to put. The tire installer has stated that there should be no rubbing and the rims will stick out in the front by 1/2 inch which would make the 2006 Cayenne look mean! :-)
Not sure what the tire installer's mention of looking mean is but it would look nice. What do you say?
The correct tire size to use is 275/40/20. A "45" profile tire is nearly an inch too much overall diameter.
Edited by spooltime
Thanks for your reply. Is is okay to have that? I did see a picture of the rims on a previous install with a Cayenne and it looked nice.
If you have a Tiptronic, the gearbox will show a strange switching behavior in automatic mode due by a changed final drive, 45 instead of 40 for the same 20" rim.
