Purge Valve Replacement on Cayenne V6
I have 05 Cayennee V6, and I think I need to replace purge valve according to other posts here.
After I had refuled the other day, idle was really rough and it would even die.
After consuming about 1/4 of a tank, idle came back to normal and car drives fine.
Is this normal with purge valve issue?
As long as i don't have the full tank, is it going to be ok?
I did see the tutorial on V8, but I think V6 is not the same.
Does anyone know where is purge valve located and how to replace?
Thank you in advance for any help.
