Seat Belt Adjuster B-Pillar - Getting cover back on
This is to help all those who have removed the seat belt adjuster the wrong way (I did it too, that’s how I know) and couldn’t get the cover back on.
Firstly remove the piece that is still attached to the seat belt adjusting mechanism. You do this by levering it off. It is clipped in place with a centering pin into the seat belt fixing bolt. It makes a strange noise but it will come off. I used a proprietry trim removing tool, but a large screwdriver should work.
Refer to attached photo
You then have a metal piece C, a plastic piece A. You will also have the cover D, that you took off before, with the metal clip B in it .
Remove B from D
Insert C into D
Refit B into D (this will hold item B in place)
Lastly clip in item A
You now have the whole item in one piece, which can be refitted to the car.
Hope that’s some help.
