Airbag light and Unlock lock issue - Think they're related
I have these error codes. I am very confident they are related now as I was having intermittent lock issues.
I can't lock my door sometimes when I close the drivers door, when I open it suddenly my car can be locked and unlocked. Tried the keyfob tricks etc, none worked.
Then recently my airbag light has come on. I cleared it but it came back on straightaway.
The door lock one is likely a mechanical problem with the door lock that prevents it from reaching it full lock position at times.
I would clear it and see if it come back.
Airbag -- Fault codes 12, 13, 28, 29, 40
Ignition circuit, driver's side airbag
Possible cause of fault
- Short circuit to B+/ground or open circuit in the wiring between the driver's side airbag unit and the airbag triggering unit
- Driver's side airbag faulty
