2005 Boxster S 3.2 engine in 2006 Cayman S
As I posted yesterday, I have found a 2006 Cayman S 3.4 with two bad cylinders (2 & 5 are pitted). I located a 2005 Boxster S 3.2 engine. I believe that both engines are VarioCam Plus. Could I use the Boxster engine in the Cayman? Would I need to change the ECU?
Best regards,
Best regards,
They are both VarioCam Plus and should both be using the 7.8.1 DME.
Thank you JFP,
Concerning the IMS bearing, I believe that the 2006 Cayman S 3.4 has the style where the engine must be opened up in order to change to the LN Engineering IMS bearing. I believe that the 2005 Boxster S 3.2 has the bearing that can be replaced without opening up the engine. Do you agree?
Best regards,
Thank you JFP,
Best regards,
Not completely; the 2006 engine definitely does not have the serviceable IMS bearing, but the 2005 may or may not (visual inspection is required) as they came both ways.
