If you have no proof of the previous owner, a stamped service manual or a detailed invoice, just replace the brake fluid.
If you use the bleeding function on PST2 (and I presume other systems will be the same) then prepare to use a whole lot of brake fliuid. When you press the pedal, the reservoir empties very quickly!! this can be an issue if you are working alone...... I ended up using three litres of fluid to completely flush the system.... I am sure I would have used much less if I had someone to help me when I did this job!
