  • ×   Pasted as rich text.   Paste as plain text instead
  • Similar Content
    • By afilsinger
      I am starting to prepare my car for a track day at Chuckwalla valley raceway at the end of the month, and I was told that the car as it sits has oiling issues?  My car is a 2003 Carrera.  I bought the car last year with 74k miles and immediately did the following:  LN IMS bearing, Waterpump, coil packs, spark plugs, all filters and fluids, clutch + flywheel and a stock AOS. In anticipation of the event, I am going to do an oil change from M1 0w-40 to the Joe Gibbs dt40 oil suggested by Jake Raby along with fresh filters.  Is there anything else I need to do to not have oil starvation?  Is this issue blown out of proportion?  does the 2qt sump extension make that much of a difference? will it affect the streetability?  I am running 200tw tires.
    • By scott vickers
      Carrera S fast Fly BY
    • By leSundancekid
      Hello everyone, I am new to the forum. I own a 98, bone stock, manual Carrera and here is my attempt at scattering the clouds over 996. Hope you'll like & share.
    • By HomePro
      I plan to replace the RMS and IMSB on my 2003, Carrera, Coupe, 3.6, Tiptronic.  I have read about the MB version of the Tiptronic requiring the removal of the trans/engine together while the ZF can be removed separately.  Is this true and how can I determine which one that I have?  I crawled underneath and could not see an I.D. tag.  So far I have found conflicting information regarding the trans. in this car.
    • By Carerra
      2010 C2S 108K miles
      I was planning to replace the plugs.  I went to remove the mufflers.  They were very corroded - especially the two I do not have to remove.  I used penetrating oil (acetone + AFT).  They are much prettier, but they are still corroded.
      Here is a 1 min video of the bolts so you can see what I am facing:
      Questions:
      If I get started on removing them and it does not go well, what next?  Surely I don't have to replace the catalytic converters?  Are the bolts somehow replaceable?
      Do they look too far gone?
