Multifunction map does not load
Once in a while when I start up the 2014 Cayenne GTS the C It just says Map loading, but the dash GPS/Map works fine. Also at the same time the phone also does not connect - with "No phone connected" in blue on the PCM screen. This happens once every 10 times or so I turn on the vehicle.
I have even tried to stop the car at a light, turn it off, open the door and lock it - but still will not connect once I start the vehicle.
Other times it works without a problem. Anyone have this problem or know how to fix it?
Edited by Sepman1
