Intermittent Radio Signal
MY 2001 - The radio signal will periodiaclly come in and out.  When it goes out the radio is unlistenable all static as if its struggling to pull in the signa.  I was reading in the 997 forums there are some transistiors under the pop up wing that can be replaced.  is that the same w/ the 996.
I have pulled the radio and the antenna is propery connected, not sure what else to check, but its pretty annoying.
If the antenna in the front windscreen is in good condition, check the antenna amplifier, which is located inside the right A pillar, they occasionally become defective. You must disassemble the pillar trim to reach it.
