You still need to remove the door panel.  Here is a writeup over on Rennlist
http://rennlist.com/forums/997-forum/579225-diy-997-door-panel-removal.html
Item 25 is held in place with melted rivets.  Some people use a soldering iron to remove the old trim and screws to retain the new.
http://rennlist.com/forums/997-forum/824787-replace-dooor-handle-trim.html
The ones on a Caymen are similar, here is a procedure on Planet -9
http://www.planet-9.com/reviews/cayman-cosmetic-mods/p193-door-panel2f-finisher-removal.html
Edited by wwilliams88
