Hi. Im a newbie to the forum looking for some part number clarification please.
I have searched the numbers in this forum but found no matches so made a new post. I hope you can help me out.
I recently bought a pair of Calipers - I was told these were off a 996 but when i searched google i found a link saying they are infact boxster calipers. I need to know which model these came off and if they are front or rear calipers.
Here are the part numbers from my mine
996.351.425
996.351.426
Could anyone also give me part numbers for the correct brake pads to use with these calipers.
Also, looking on e-ebay i found a link to a set of new calipers with part numbers
996.352.425
996.352.425
could anyone tell me what these calipers are off please.
Thanks in advance!
Simon
996.351.425.xx and 996.351.426.xx are front calipers (left and right) for a 996. The xx would designate whether the car is a C2 (2WD) or C4 (4WD).
996.352.425.xx and 996.352.425.xx are rear calipers (left and right) for a 996. The xx would designate whether the car is a C2 (2WD) or C4 (4WD).
Factory front pads are: 996 352 949 02
Factory rear pads are: 996 352 939 03
The Boxster S uses the same front calipers as a 996 except the are red.
Thanks for the reply Loren.
The calipers i have at the moment are the red ones.
Would the same apply to the part numbers for the rear brakes (if they are red they are boxster s?
Could you tell me the standard disc size and width for the front boxster s calipers please?
Regards
Simon
The red rear brake calipers for the Boxster are 996 352 421 13. They are the exact same size as the 996 standard brakes - just red.
Boxster S front rotors are 318 mm, rears are 299 mm - same as the 996. I have no idea what you mean by width.
