2000 996 Carrera 2 coupe 6 speed - Oil pressure sender
Easiest is to go from below with a crowfoot and a long wobble 3/8" drive extension (availabe at harbourfreight). Or you can use a u-joint, which will not have as much leverage as a wobble extension though. I don't know the torque spec but there's a crush washer you need to compress. I would not go crazy tightening it though as long as you feel the washer is compressed.
I would like to replace the oil pressure sender.  Could somebody advise the required torque and confirm that the replacement can be done from the top using a crow foot wrench?
19 ftlb plus or minus 3.5 ftlb.
Yes, likely a stubby crows foot.
Many thanks, Ahsai.
Many thanks, Loren.
