I have a 2007 997 Cs4 and have just bought a genuine Durametric diagnostic cable. Does anyone know where I can download a complete list of all the fault codes please ?
I have fault code 8005 Terminal S ? on the PAS and am struggling to find out what it means. Any help much appreciated
The complete list is only available in the Porsche Service Manuals.
PAS Fault 8005 - Terminal 86S
Possible fault causes
- Wiring between PAS control module and terminal 86S relay faulty
- Open circuit in the power supply
- Terminal 86S relay faulty
- PAS control module faulty
Terminal 86S relay does not function and therefore no other control modules (airbag control module,…) function either.
Hi Loren
Thanks for your response. The airbag control module etc function ok so I assume the Terminal 86s relay is ok. Do you know the location of Terminal 86 S so I can check the connections etc ?
Hi Loren
(click to enlarge)
