Does anyone try the following two procedures to reprogram their keyless remote for 1999 996?  I found this via google search and wonder anyone here have tried it.  Both of my remotes are dead and looking for options to reprogram a new remote purchase from on-line dealers.   My local dealer gave me a quote about $300 for key and reprogramming for one remote.  I like to get two remote so I have a backup and that would to $600!
1. Close the vehicle .
2. Turn OFF the ignition.
3. Remove the key from the ignition.
4. Press and hold the driver side door lock switch in the UNLOCK position.
5. Insert the ignition key into the ignition lock cylinder and remove the key. (Do not turn the ignition key in the lock cylinder.)
6. Insert the ignition key into the ignition lock cylinder and remove the key. (Do not turn the ignition key in the lock cylinder.)
7. Insert the ignition key into the ignition lock cylinder. (Do not turn the ignition key in the lock cylinder.) Leave the ignition key in the ignition lock cylinder.
8. Release the door lock switch. The vehicle will sound three beeps in order to verify the Program Mode has been activated.
9. Press the LOCK and UNLOCK buttons together on the keyless entry transmitter and hold until the vehicle beeps twice to verify that the transmitter has been successfully programmed (this take approximately 15 seconds).
10. Perform the previous step to program up to four transmitters (including your old ones).
11. Remove the ignition key in order to exit the Program Mode
Here's another one:
1) Turn ignition to OFF.
2) Locate the
 Link Connector, its a black 16 pin connecter that is under the driver's side dash, right where your right knee would be. You have to look up into the dash from below to see it.
3) Ground pin 1 of the Data Link Connector by taking a wire or paper clip and running it from pin 1 to pin 4. Pin 4 is ground so you can just short pin 1 to 4 and it will be grounded. Grounding pin 1 tells the system you are ready to reprogram it.
4) Close all of your doors.
5) Turn the key to ACC then back off. The power door will lock/unlock. This is the signal that the system is ready for reprogramming.
6) Push a button on your key fob, doesn't matter which button.
7) If you have 2 key fobs, then press a button on the 2nd fob within 1 minute of pressing a button on the 1st fob. Both must be programmed at the same time. If you only have 1 fob then press a button 2 more times to signal that you only have one.
8) The doors will lock/unlock to signal the codes were received.
9) Remove the jumper wire from the data connector. 10) your done
Knowing how this system works, I seriously doubt either of these proceedures are going to do anything other than waste your time.
You problem is that in order to change the remotes out, you need to reprogram the car to accept them, which requires either a PST II or a PIWIS system.
JFP in PA is correct.
If these procedures actually worked I think there would be a lot of stolen Porsche's.
I have actually programmed (new) keys to cars using a PST2 and PIWIS - there are IPAS codes needed as well as original unique key number code.
Only 4 keys can be programmed at any one time - and to overwrite one of the 4 key codes you need the original key and the unique key number code.
Those procedures may have worked on older cars but not on 996 or newer Porsches.
I have two Audi and they both have procedures similar to what I found listed above for programming new remote so I was really hoping that this procedures can be done also for Porsche.  But with that said it is almost universally knowledge that when your remote failed(and looks like it fails pretty regularly) that you just bring it to the dealer and they charge you the price of buying a smart phone for a simple remote. :censored:   Anyway I think I have to order the remote anyway and from searching the forum look like Sunset Porsche has the best price.  I will give a go since I do have some time to waste; if it doesn't work I will bring to the dealer to get it program.  If anyone have try this please chime in working or not since this is the purpose of this forums.
I was in the same situation, and after a bad experience with Sunset Porsche, I won't do business with them anymore.  I found keys on eBay (with the serial number tags) for @ $140, and had a local specialty locksmith come and do the programming, which cost another $100-$150 (don't remember exactly).  We swapped the blades into new heads, obviously.  I was originally told that only the dealer could do the reprogramming, but this is not correct, there are quite a number of places that will do it in most major metro areas.
As noted, it is the car that needs to be programmed to accept the key, not the other way around.
Then there is this one:
1. Go to the shed and get the wheelbarrow.
2. Bring the wheelbarrow to the bank and have them fill it with twenties.
3. Bring the wheelbarrow full of twenties to the dealer and tell them you need a new remote programed for your car.
4. Bring your new remote and your empty wheelbarrow home.
5. Put the wheelbarrow back in the shed for next time.
+1  :notworthy:
  • 10 years later...
For the steps #1: I don't know of what are the doubts about these steps as for the sq. #1 there is same button on the keyfob for all 996/986 to lock/unlock. Which cannot be pressed TOGETHER as it is just the same button. Brrr....
Steps #2: I never tried these steps but for 996/986 programming the keyfobs and immobilizer are separate procedures. Even if hypothetically these steps would add the 2nd keyfob to the car with shortened pins #1 and 4; the key needs to be programmed to the immobilizer.
  • 8 months later...
Im a DIY guy and the key fob is the only reason i take my car to a dealership. They engineered this against global theft , which was a bigger problem in the 90s, but they require you to bring a title certificate and drivers license and then they program it (and your other keys if you have more than one. each has their own profile such that each key triggers customized seat-positions and stuff) for about one hour labor which costed me about 280$
They do require that the blade , if needing cut, be purchased through them as authentic, and charge 80$ i think on top of that.  I went into the suburbs of my city where it was a bit cheaper and quickly done. they keep these in stock at all dealerships.
