  • ×   Pasted as rich text.   Paste as plain text instead
  • Similar Content
    • By Michael hurta
      Hi - 2002 996: Scoured the lists but can't find this particular cluster problem anywhere.  In short, my salvage cluster shows a list of errors on start up but my original was fine....  Here's the details.  My current cluster shows an intermittent airbag failure warning on the led screen followed by the idiot light.  It usually occurs at start up, clears at the stalk and the idiot light remains on, but flickers on occasion.  My mechanic had ruled out everything he could related to the airbag warnings and since he didn't have a spare cluster, couldn't swap to test for that. I personally purchased a salvage cluster, removed the battery terminals, installed it and it came to life (I'm also having to buy replacement connector housings because mine disintegrated).  The problem is the info screen pretty much scrolled through a variety of issues like oil pressure feedback, temp feedback, fuel feedback, etc.  The oil pressure gage was also unresponsive.  I expected the odometer to be wrong, but didn't expect all the errors.  I also started the car and while it ran, it did run rough, sputtered a bit.  Do I have a bad salvaged cluster?  Does the cluster need to be programmed (beside the odometer)?
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By stephen magee
      wires came out of my camshaft sensor and not sure what order they are
    • By Silver_TT
      2002 Carrera 4S. I did a search and didn't see these exact symptoms simultaneously.
      See attached picture. I was driving at 5k RPM in 3rd when the power of the car was suddenly reduced (by the computer I believe) and the console beeped displaying the following 4 checks: 1. Brake distribution 2. PSM failure 3. ABS failure 4. Battery -- also, as you can see in the pic, the battery voltage meter is maxing out. When I disengage the clutch from the engine the voltage drops some (and the brake/ PSM/ ABS messages go away and are temporarily ok) but is still running significantly higher than what I'm used to seeing. Could this high voltage be damaging to the electronics system? Presumably there's something going on with the voltage regulator. Does the ABS/ PSM turn off automatically for saftey when there are voltage spikes?
      My battery is an Interstate and is ~ 1yr old. This seems to me like the alternator (possibly the voltage regulator). I realize it would be better if I had a Durametric to hook it up to and get the exact error codes off of. That may need to be done to properly diagnose what's going on here.
      Thanks in advance for any help/input.
      Cheers,
      Alex
    • By Kevin Bryck
      Okay this is REALLY specific.
      The adjustable tension cable on the drivers side of my cabriolet disconnected at the top where it threads (8mm) into the top frame, not at the bottom where it snaps onto the ball.
      The is a larger diameter (10mm?) clean smooth painted hole where the cable needs to thread in, which leads to the presumption that there was a nut on the back side?
      Searched all over including removing driver's side rear 'door' panel and fishing around with a magnet but no loose nut found.
      Looks like getting to back side of this frame casting would entail a major disassembly of the cabriolet top frame?
      Also, what does this clip that goes over hydraulic cylinder do?
      Right side clips is in place about halfway down length of cylinder.
      Left side clip was down around the base of the shaft.
      Replacing it where there appears to be a shiny spot looks like it would interfere with the cabriolet top potentiometer arm.
      Right cable threaded into frame at top
      Missing cable location
      Smooth clean painted hole in top frame where 8mm cable end is supposed to thread in
      Left cable
      Left upper cable end with 8mm thread
      Clip question
