Can Someone please tell me how I can remove the cubbies, radio, AC controls and batwing from the Center stack, I would greatly apprecite it.
By the way if its possible I want to hardwire my Magellan Roadmate 500 for power and audio. What materials do I need for power and where do I get it from. ( I already hardwired my V1)
You will need the Becker keys for the radio removal the rest either unsnaps or unscrews once the trim frame is snapped off.
(photos courtesy of Tom Morris)
Down below and behind the radio/storage shelfs is phone prep connector with both switched and unswitched 12 volts.
+12 volts unswitched (red/green)
+12 volts switched (green/black)
Ground (brown wire)
Telephone Mute Signal (yellow/black wire)
0. Pry out button panels(left & right) from bottom to top
1. Radio - pull out using the radio removal tools as Loren said.
2. AC - pry out the AC surrounding bezel , remove 2 screws on the top(left and right).
3. Batwing - prying out the leather paddings, in turn, the batwing from the side.
I head Magellan sells the wires, but never seen one.
