Hi All,
Just looking for some more information on the following.
2011 cayenne 3.6L
B101713 - Drivers Side - Side Airbag - Pressure Sensor, Open Circuit
Thanks kindly!
I think More importantly im looking to find out if this is for the igniter in the seat or the impact sensor on the floor pan?
the fault was pulled with a Piwis Tester II and im not familiar with the "pressure sensor" wording
thanks!
Edited by EleCTriCT
So the "Pressure Sensor" is bolted to the inside of the inner door panel of the drivers door.
the vehicle had a broken wire in the door jamb - causing the intermittent fault - the wire was repaired and the sensor was still replaced for good measure since the door was all apart.
cheers
Edited by EleCTriCT
