Eric,
Check under the vehicle menu on your multi-instrument-display in the dash. There is a setting there that allows for setting volume for all the audible warnings. It's probably down a few levels in the menus. To save it so it doesn't revert - after setting it - set your seat # again (press SET, then the seat# button.) Then after stopping and getting out of the vehicle - lock it using the key. If you don't do these - whatever it is now will simply reappear next time you unlock or start the vehicle.
