Question: What is the minimum F+R rotor thickness for 991 C2S
Hello,
Wanted to check how far worn my front and rear brakes are. Car is a 2012 991 Carrera S.
Does anyone have the specs for the minimum front and rear rotor thicknesses?
- Sanjeev
Loren
Thanks. This is great info.
I wasn't aware that Porsche rotors could be machined, but it makes sense that as long as there is enough residual thickness above the minimum, then it should be OK. Makes it easier to replace pads and freshen the rotor surface to allow for a proper bed-in of the contact surfaces.
- Sanjeev
