Hi, this is very stressed me out, here is a long story; 1 month ago that my 04 CTT's driver side fuel pump went out, thanks this forum that i searched and pulled the fuse to force run on the passenger pump to drove couple days, it was running fine and i didnt drive hard, car was totally normal. the nightmare comes after the new fuel pumps came in, i changed both but now sometimes it gets so hard to start, have to crank for 20-30 seconds even it finally starts it will stall in 1 second that i have to press on gas to make it alive(never happen during cold start in the morning, only happens after i drove it and parked for like 10-30 minutes, drove on the freeway, if i try to pass or accelerate the fuel will cut off and engine turned off, i had to put in neutral to move the car on the shoulder and start it again to drive away which is very dangerous. i installed the old fuel pumps back and pulled the left pump fuse, same thing! which didnt happen when my old driver pump went bad.
Whats the magic here? i assumed that i connected a fuel line wrong between the pumps? but the car drives fine most of the times, someone please help, thank you!
if its not stalling during warm up it means all fuel pluming is fine
disconnect mafs and start the car
please reply back
