Does anyone have a measurement for how much droop is too much?  Measured from the chassis to the carrier, not exhaust tips?
Edited by JTT
Thanks Loren.  I read a lot about exhaust tips drooping low on one side or other, and cabin vibration as indicators as well as leaks and tears.  I just figured there was something more "measurable".
I have no visible leaks, tears or obvious deterioration (as you can see in pic).  Both exhaust tips are equal height, but I seem to have a little vibration at idle I can feel through the wheel, that I don't remember feeling when I first got the car two seasons ago.
Just as a follow up to this post, here are a couple of pics.
First is new mount installed.  You can see compared to the pic in earlier post there is a considerable difference in the clearance from the chassis to the carrier.
The second shows the old and new sitting side by side on the bench.  Hope this helps others.
  • 4 weeks later...
