  • ×   Pasted as rich text.   Paste as plain text instead
  • Similar Content
    • By SPIRO
      Hi everyone.  My 2006 Boxster S suddenly started making a squealing noise.  Noise goes away at higher RPM, only to come back at lower RPM and at idle. Not related to gear or clutching at all. Noise seems loudest at the rear of the car; I can hardly hear it inside with the windows closed.  Is this a serpentine belt issue? Or the bearing of some engine accessory? I have 50,000 miles, and have already changed the serpentine belt once, around 4-5 years ago,  just due to age of the car. I have not yet had the time to open up the engine compartment to look further. If it's a belt, then I would expect more noise from inside the cabin, would I not?  I have attached a recording indicating the squeal going away when I rev the engine.
      Recording 26.wav
    • By Garra671
      Tried googeleing it but couldn’t find what I was after.    Was curious if anyone knows what type of flat 6 the 986 boxster has?
      Is it a a true boxer engine? Or a horizontally opposed flat V?     True boxer meaning it has individual crank pins for each piston and is a true 180degree angle.    Thanks in advance
    • By wcp
      My front wheel was making a rattling noise for about the last week, and this morning as I drove out of my driveway and turned the wheel, I could hear a loud popping noise coming from my wheel whenever I turned. My best guess is that I drove over a pothole and the control arm / bushing moved out of place. Would this be covered under the OE warranty? Or should I take it to a mechanic?
    • By Almamo
      Hi all, I just joined the group and am having some problems with my 2005 Porsche Cayenne.
      When I drive a few miles it stalls and I see a message saying Reduction on and reduction off. I your help please, and thank you in advance for your assistance.
    • By ALAllen
      Hi there, my Cayenne is telling me my driver's side door is open when it is not. This is causing the dome light to stay on. Not sure what the issue is and if can be fixed easily. Any info given is greatly appreciated, thanks!
