Click here to Donate
Sign in to follow this
Doug_B_928
2008 Porsche Cayenne S Variable Valve Solenoid Replacement
The attached pdf is a write-up from my recent variable valve lifter solenoid replacement.  It's a newbie-rated, detailed, pic-intensive write-up.  This is a simple task but, due to a number of factors identified in the write-up, it can be difficult and at times frustrating.  If I were to do it again I'd probably use the intake manifold removal method.  But, in case anyone is curious, this pdf details how I did it. 2008 Porsche Cayenne S Variable Valve Solenoid Replacement.pdf
Share this post
Link to post
