Bear with me as i Am trying to sort my problems one by one. Sometimes, the doors of my cayenne cannot be opened right away either from the inside or outside. If coming from outside, i have to grab the handle and push the doors inward before i can open it. If from the inside, i have to pull or yank the door handle a little bit before i can open the doors. It gets embarassing if you have a passenger who cant get in or out without telling them how to open the doors. I dont know if it is connected but i cannot communicate with kessy. Did the $5 fix but fuse 40 keeps blowing so did not bother to fix it anymore when finally it did not blow after 4 fuses and i have code 1299.
Thanks in advance.
2004 cayenne turbo
Sent from my iPhone using Tapatalk
Don't mean to ask a silly question or offend but when the car is locked the handle outside needs to pulled twice to unlock and open. This is normal for kessy cars. Also if your car is set to auto lock when driving above 15km/h or what ever it is set at, when you stop you must pull the inside door handle twice to open the door.
I'm not sure if this relates to your issue but thought it was prudent to state the obvious incase it was misunderstood.
The kessy module can play up and the result is the handles don't work well on command or don't work at all. Read the thread about this and the fixes possible.
