Airbag warning light
Hi all. I'm a newbie,recently purchased a 996tt and I'm having an issue with the above tittle. The battery went flat so I replaced it but now I have the Airbag warning light issue. Had the car on a Porsche Diagnostic machine and it says the Airbag control unit is dead/dying. So,I've now replaced with a tested second hand unit,same part number and correct amount of airbags etc. I've started the car up and the light is still on. My question is,do I need to get the Fault codes read/cancelled before the light will go out or should it of gone out on its own if all was good with the system??
You need to correctly clear the fault code.
  • Like 1
Hi. Update,so I brought and fitted matching used Airbag control unit,cleared all but one code which is 72-16 the Child seat detection leak resistance/short to B+ so I presume the donor part came off a car with child seat ISO fitted.
so my new question is,
Can a second hand unit be reprogrammed to turn off the child seat warning or can they only be programmed once,i.e when Blank/new??
No, the child seat option can simply be turned off.
