  • ×   Pasted as rich text.   Paste as plain text instead
  • Similar Content
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
    • By Silver_TT
      2002 Carrera 4S. I did a search and didn't see these exact symptoms simultaneously.
      See attached picture. I was driving at 5k RPM in 3rd when the power of the car was suddenly reduced (by the computer I believe) and the console beeped displaying the following 4 checks: 1. Brake distribution 2. PSM failure 3. ABS failure 4. Battery -- also, as you can see in the pic, the battery voltage meter is maxing out. When I disengage the clutch from the engine the voltage drops some (and the brake/ PSM/ ABS messages go away and are temporarily ok) but is still running significantly higher than what I'm used to seeing. Could this high voltage be damaging to the electronics system? Presumably there's something going on with the voltage regulator. Does the ABS/ PSM turn off automatically for saftey when there are voltage spikes?
      My battery is an Interstate and is ~ 1yr old. This seems to me like the alternator (possibly the voltage regulator). I realize it would be better if I had a Durametric to hook it up to and get the exact error codes off of. That may need to be done to properly diagnose what's going on here.
      Thanks in advance for any help/input.
      Cheers,
      Alex
    • By Kevin Bryck
      Okay this is REALLY specific.
      The adjustable tension cable on the drivers side of my cabriolet disconnected at the top where it threads (8mm) into the top frame, not at the bottom where it snaps onto the ball.
      The is a larger diameter (10mm?) clean smooth painted hole where the cable needs to thread in, which leads to the presumption that there was a nut on the back side?
      Searched all over including removing driver's side rear 'door' panel and fishing around with a magnet but no loose nut found.
      Looks like getting to back side of this frame casting would entail a major disassembly of the cabriolet top frame?
      Also, what does this clip that goes over hydraulic cylinder do?
      Right side clips is in place about halfway down length of cylinder.
      Left side clip was down around the base of the shaft.
      Replacing it where there appears to be a shiny spot looks like it would interfere with the cabriolet top potentiometer arm.
      Right cable threaded into frame at top
      Missing cable location
      Smooth clean painted hole in top frame where 8mm cable end is supposed to thread in
      Left cable
      Left upper cable end with 8mm thread
      Clip question
    • By loganmarriott
      Hello
      I have a tough question for any advanced Renntech users who have either stripped a 997 back to minimum wiring for racing, or fixed key issues
      Can anyone help with my alarm issues.
      Im building a 997 Track car- using a salvage chassis and the remaining parts from a rolled and written off cabriolet. Im think the key worked to unlock to car before i pulled it apart, but cant be certain as the engine was already out so there were limit functions to activate then.
      Since moving the dashboard and whole wiring loom into race chassis, I can unlock the doors (yes, its the correct key, ive moved the doors over too), and the dashboard lights up to tell me the current odometer values. However the whole time from when the battery is connected, the alarm siren is going off (currently a clamp muffles that noise to save the neighbors). I can put the key in the barrel, rotate, and then still remove it (the Barrel lock appears to electrically be live, as it releases the key).
      My guess if that the key has lost its coding for the alarm system, but I've tried following these instructions, https://rennlist.com/forums/997-foru...working-2.html,
      with all combinations of button holding, pushing the hazard light switch, foot on brake, and key in/out barrel .... without any success in recoding the key.
      Its worth noting the windows dont go through the usual drop down upon lifting the door latch sequence, im assuming this is due to the alarm running.
      Any suggestions.
      - my options seem to be getting the local agent to reprogram the key
      - are there any other steps i should try to revive the key. I do only have 1 for the wrecked chassis's system
      - a final last though is am i missing some switch that needs bridging from the cabriolet circuits to tell if the roof is down/up
      Regards
      Logan Marriott
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Lost Radio Code - post your request here
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
