97 Boxster crank no start
4 hours ago, Justin Boisclaire said:
I got my module back, i tested my cps and it is good. How do i test my dme?
That is going to require access to a Porsche factory diagnostic system such as the current PIWIS or earlier PST II.
34 minutes ago, Justin Boisclaire said:
So i guess everything else is ruled out and it is the DME, any suggestions on how to test or replace it?
See the above; testing or replacement is going to require the Porsche diagnostic system......................and bring money as a new DME is about $2K sitting in a box on the counter, plus and hour or two of programing time, if it really is the DME.......
1 hour ago, Justin Boisclaire said:
Do can i find a used DME and put it in?
Even a used DME (same version number) would require reprograming by a PIWIS system.  The DME in these cars is the center of everything, even your odometer miles are stored in the DME.
58 minutes ago, Justin Boisclaire said:
Just not sure what my next step should be. Not sure what else I should diagnose to rule out the dme. Not sure if I should just part out the car and cut my losses.
The only way to rule out the DME is through diagnostic's, so there is going to be at least some $ involved. And just as a side note on the subject, in all the years we have been working on these cars, I have seen very few DME failures, fewer than I can count on one hand.
