  • ×   Pasted as rich text.   Paste as plain text instead
  • Similar Content
    • By Graeme Tate
      I hate my pig but I love my pig, can anyone please help me before I send it for scrap. Over the space of the last 4 years of ownership my car has been in the Porsche dealers for 2 years in total with suspension problems, to cut a long story short this is now sorted and was due to a faulty replacement air bag being fitted. Moving on after 3 months of (almost) trouble free motoring this is what’s happening now and would love some advice as the closest porsche dealers is over 200 miles away from me.
      When I picked up the car from Porsche  it ran out of petrol before I got to the garage at the end of the road and although I filled it up it  the engine warning light remained on I assumed this was just fuel related and drove home with it on and reset it when I got home.
      Wind on a few weeks and the engine light came back on and gave me a camshaft position sensor error p0016 so I sent the car to my local Porsche mechanic who changed out the sensor and did a full service on the car including plugs filter oil etc etc. All this time the car has been running fine but as I wanted the sensor light out it was changed. However after changing it out the light came back on almost straight away. The car has been a bit sluggish to start sometimes and sometimes on pulling away from a stop has also been hesitant.
      This was about 3-4 weeks ago and now it is worse again, at tickover it’s noisy, it doesn’t like acceleration and is running really rough although if you are going over 50mph it doesn’t have a problem and seems to run fine. The EML is now flashing rather than being a solid light. I attach a video of it running.
      Any thoughts would be a help before I decide to get it hauled back across again
      Sent from my iPhone
    • By longrowe
      I have a 1998, ROW C2. Over the past two weeks I have noticed that the fuel gauge is not reading correctly. The gauge will read high (3/4) but as I drive, the gauge will slowly drop to the correct reading over about 15 minutes. As the car sits, either at work for the day or in the garage overnight, when I go to start the car, the gauge will read over 1/4 tank higher than when I shut it off. Then, as I drive, it will drop to where I think it should be (or remember where it should be). I plan to pull the sender this weekend and check the connections, but I don't think it is the float as why would it rise while the car is turned off? Is it possible to troubleshoot the cluster gauge? I have a Durametric so I will attempt the fuel level calibration when I have pumped down the tank. Or am I just fooling myself and the gauge is bad?
    • By dyerhaus
      I’m having a weird ‘fuel thing’ with my 2001 Porsche 911… So, I’ve been thinking it gets terrible gas mileage, compared to my 986 Boxster. I expected slightly less, but, it seems pretty bad. Now, I can’t help but wonder if there’s actually something amiss about it.
      When I fill the tank completely—and I mean ‘topping it off’ to get every last drop in, my fuel gauge usually looks like this (see the first picture, 01).
      That picture was taken immediately after starting the car after filling up the tank (I was still at the pump). There have been occasions where the needle has gone all the way to just slightly past the 4/4 mark (just like the Boxster always does), but it usually lands below as seen in the photo.
      However, today I was down to the warning light coming on telling me I’m low on gas. I stopped to fill it up and it only took about $30 worth. That’s odd, with gas prices here and filling up an almost empty tank, that should have been between $44 and $48 (that's what the Boxster runs). I tried to top it off but it wouldn’t take any more, as if the tank was full.
      So, I got in the car and started it, and (just like before) this picture was taken immediately after starting the car after filling up the tank (I was still at the pump) - (see the second picture, 02).
      Just barely over half a thank.
      Any idea what could be going on with this?
    • By SpawnyWhippet
      I  have a 2009 997.2 PDK Carrera 2 and am getting a loss of power and this error code:
      2510: Fuel high-pressure control - adaptation. Value below lower limit value
        I believe this means my HPFP is dead and am looking for the workshop procedure for replacing the high pressure fuel pump HPFP. I have looked far and wide for a DIY tutorial on this, but found nothing. My local stealership will do the work for $900 labor plus parts. I have sourced the pump for $850 and want to do the work myself. The pump looks readily accessible at the back right end of the engine, facing the rear bumper.
      I am happy to write this up as a DIY with pics if someone can forward me the workshop manual pages or procedure?
    • By Alienz
      I have a problem with the fuel door release/actuator. Whenever I lock the door I hear this loud noise coming from the fuel door. Only happens when I lock the door. Does anyone know how to access that actuator?
