986 Camshaft Timing Sprocket Adjuster (Bracket)
I am replacing the cam timing chain ramps/pads on MY98 5 speed.  The top pad on bank 2 was completely gone and the timing chain between the cams was chain to metal on the tensioner.  The tensioner was toast and I'm replacing it.
I was re-installing the IMS chain sprocket to the exhaust camshaft and noticed a crack  in camshaft sprocket adjuster . Using my fingers I pressed it out and it split in two.  I'm looking for a replacement and can't locate one.  Any ideas?
5E76B9E6-D106-49FA-B289-D695AFFD843A_zps
CAB5C4D0-7C4B-4562-A0E8-1D90A4F83227_zps
Edited by kbrandsma
added 2nd photo
I believe that part is discontinued as an individual part, and may now only be available with the gear for around $150 under part number 996-105-178-54. You would probably be better off checking around for a used one.  I believe they were the same up until 2004 on the Boxster.  But if you can't find one, Sunset can get you the new number.
  • 11 months later...
