Engine symbol “Failure Indicator” - No start
2001 996 TT; Ran fine 1.5 mo ago. Stored with 2A trickle charger & open hood..  Get in car turn key- get Failure Indicator warning.  No start & ECU is not responding to scan tool.  Places the battery on charger; seems like power equipment is working fine.
I’ve swapped the #1 and #7 relay with O2 relay. Checked the associated C1 & B8 fuses.
Still No Start...any suggestions?
Ive read that there a common wire associated with ECU that will cause this; but no pics or good description on where on car.
A poor battery can run many things on the car but still not have enough juice to start it.  First thing I'd do is replace the battery.  BTW, trickle charging a bad battery does NOT help.  You can not resuscitate a bad battery.
