Timing chain rail orientation on 996 3.6 litre
Hi
I have question  on  proper  orientation of  the timing chain rails for cylinders 1-3 and 4-6...the attached picture refers.
I have indicated what I think their orientation should be in relation to the IMS shaft in the attached picture.
If you enlarge the picture you will see that both bolt holes nearest where I have written  "IMS shaft" are oval and the ones furthest away are round.
Please advise if I have the orientation correct
Much appreciated
