Heated Seats
Installing after market heated seats cause I"m reupholstering. The heated seat kit include fuses, one for each side. Isn't the 1 fuse at the fuse box sufficient enough rather than having 3 fuses in the circuit. I'm tapping into #6 fuse which is unused(was for heated seats option). Thanks V
Edited by vza
Well...I installed the left seat and it does heat pretty good....takes some time. I clipped the manufacturer fuse out just using the 1 fuse from the box for both seats. See how it works. V
Edited by vza
