Hi Loren,
If you could ever so nicely help me with my radio code I'd appreciate. Thank you very much!
also, the digital backlight of the radio is broken so the first letter of the serial number I can't fully read but i think it's either an X or K? The rest of the digits I know are correct.
Becker 1
4462
# X5025042
Hi Loren,
Becker 1
4462
# X5025042
Try 5491
Really hope you can help. Many thanks! Here is all the info:
Becker
CDP2081
4462
SN-2501186
24/99
Try 8476
Did not work. Any other suggestions?
Did you follow the procedure in the Lost Radio Code FAQ to get the serial number?
If not, please do and get the correct serial number.
Yes, i doit...and not worked!!!!
OK.... firstly the code given is the correct original code for your serial number.
You need to check your serial number, from the label attached to the metal casing.
I suspect you have provided the correct serial number, and it is probably the case that the radio has been re-coded to another code in the past.
The code is stored in eeprom 24c02, and if you have an eeprom programmer to read the memory contents, I can provide a code from this... If you don't have the equipment to read eeproms, then a radio decoder in your area will be able to help you..
Cheers.
Thanks Bruce201 for your help, but i havent reader to read the eeprom,the s/n is correct from the label,and from TP...
but , but nothing....
Just one other thought... the radio is allowing you to enter code?, i.e four stars appear like **** and it is not showing 'WAIT"
Sometimes radios will 'time lock', in which case you need to leave radio powered on with ignition to 'accessory' position to reset.
Failing any of those problems above... definately a job for the radio decoder.
Sorry
