Yes, I used the procedure outlined in your posting.  The serial number displayed on the face of the radio is the same as that in the photo of the label on the side of the radio that I attached above.  Serial is W5011227
Dave
Hi, I need a code for my Becker CR210.  The serial is W5011227
Thank you,
Did you use the procedure in the Lost Radio Code FAQ to get your serial number?
If not, then please read that and follow the procedure and re-post the correct serial number here.
It worked great.  Thank you, thank you, thank you!!!
Dave
Code worked.  Thank you so much
I just join the renntech group.  I am in need of a radio code for 1998 Porsche Boxster Becker 1 47/98 Ser# Y5021189 type 4362
Thank you in advance.
Benny Blades
Contributing Member
Try 8490
Code worked.  thank so much,
Benny Blades
