You are amazing. Thanks!
Same and common issue.. why doesn't owners write this code down in the manual or something. Hope you can help
Becker 4462
radio SN Y5046187..
I tried 6401, 6403, 6404
I am back to wait..
Wayne
Try 0860
or
0858
Just like magic.. you are great.. the first code worked.. THANKS
Hi, I have a 99 Boxter with locked stereo after disconnecting the battery for transport...
Becker 1
Type 4462
Ser X5021372
Any help would be greatly appreciated!!
Try 0706
or
0704
0708 did the trick (as per your FAQ). Thanks!
I wonder if anyone would be kind enough to help me... I have fallen victim to the lost radio code conundrum after a battery failure.
The car is an '01 S
The stereo is: CDR-220
Serial: Y5024619
Series: 4362
Any help figuring this out would be much appreciated.
Cheers!
The car is an '01 S
Serial: Y5024619
Series: 4362
Cheers!
Try 0601
or
0599
The car is an '01 S
Serial: Y5024619
Series: 4362
Cheers!
Try 0601
or
0599
0601 was the ticket.
Thanks so much.
Had to disconnect my battery and now the radio is locked.
CDR-220
4462
X5025056
Thanks in advance.
Try 9185
or
9193
Thanks for the quick reply, Loren. Neither of those codes worked...any other suggestions?
Help appreciated. I'm in the same boat as others, purchased vehicle without radio code, after disconnecting the battery I need the code.
'02 carrera 996
becker 1
cr220
s/n 25007995
4362
24/99
will provide vehicle vin if needed
thanks
'02 carrera 996
becker 1
cr220
s/n 25007995
4362
24/99
thanks
Try 7375
or
7371
Just had the original battery replaced in the 97 Boxster I bought a year ago and, of course, unable to locate the radio code card. The forums have been a great help in finding the s/n and I'm hopeful that I can get the 4-digit code so I can enjoy some tunes during the great summer weather.
'97 Boxster (German vehicle brought into US)
Radio is a CR-21 with a 6 disc changer in front trunk.
Model R1996
S/N V5002786
Hope you can help with a code.
Thanks.
Try 2565
or
2563
Thanks Loren. Unfortunately I tried 2560 through 2569 and no luck. Is there anything else I can try?
Model R1996
S/N V5002786
Thanks.
Try 2565
or
2563
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Thank you, I am greatful for the tip. I will have to 'wait' to try the variances that you suggest in earlier posts.
The dealer I purchased the car from has yet to get back to me with any info (it has only been a day, but i got an answer here in an hour or so)
'02 carrera 996
becker 1
cr220
s/n 25007995
4362
24/99
thanks
Try 7375
or
7371
