Hey!
I took my car into the shop and when it came back my 2000 Porsche Boxster’s radio asked for a code. I have no  idea what it could be but if y’all could help me the would be amazing!
type- 4462
serial number- Y5040989
radio- CDR-220
8 hours ago, Brianna said:
Hey!
type- 4462
radio- CDR-220
Try 8907
  • Thanks 1
Looking for help with my 2000 996 C4 with a radio card the does not work.
My radio code is not working and the one the Porsche Dealership provided also does not work.
Radio CDR-220
My radio card details:
BE 4462 W 5010425 code 4906. (Does not work)
The Porsche Dealer provided a code of 1528. (Does not work)
In addition, I have a Becker card with the following serial number CDC-3 X1039282.
Thanks in advance for everyone help.
Radio CDR-220
If that is the correct serial number (per the procedure in the  Lost Radio Code FAQ) then it is likely that radio has been repaired by some 3rd party other than Becker. If that is the case I can not help you.
10 minutes ago, Stefano Sharma said:
Replaced my battery and the radio code for my CR-220 isn’t working. Bought the car used so it’s possible the code is incorrect. Looking to try another code. Thank you!
Radio - CR-220
SN - X5020347
Type - 4362
Try 0698
Thanks Loren,
Based on the serial numbers I do have what 4 digit code do you think would work?
52 minutes ago, Colin Carter said:
Thanks Loren,
If the code I gave you does not work then you need to get Becker to unlock the radio or replace the radio.
