Sorry I was not clearer.
What I meant was is there anyway to have the radio display it's code before it's deactivated by disconnecting the battery?
Radio is working fine right now but will deactivate once I disconnect the battery to install a new ignition switch.
Bill
Bill
The procedure is the same before or after battery disconnect. See the instructions in the FAQ.
No radio code..
Becker CR-220, type 4462, X5023685, Thanks!
Try 4399
or
4397
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Hi again
Thank you for your suggestions but the codes did not work for my radio. I have tried +-2 several times with no success.
Would appreciate if you have ideas?
einesv996
No radio code..
Try 4399
or
4397
Hi again
einesv996
PLEASE read the FAQ.
I have a 1999 Boxter 2.5 and replaced battery and now cannot locate the unlock code.
CR-220
Becker 1
Type 4362
SN: X5013228
Thanks in advacned!
Try 8422
or
8420
Thanks Loren, the code(s) didnt work. Will try more when the radio resets. Thanks for your time.
