Hi Loren,
I would appreciate any assistance you can provide.   I replaced the car battery and alas the radio needs a code; unfortunately I can't locate it.  It is a Becker CDR-210 model 2282 serial # V5017243; thank you again for your help.
3 hours ago, Blue Box said:
Hi Loren,
Try 4702
24 minutes ago, Blue Box said:
Hi, thank you for the code unfortunately  it didn't unlock the radio.  I tried 4700 thru 4722.  Any chance there is an alternate code?  Thanks.
Did you use the procedure in the Lost Radio Code FAQ  to get the correct serial number (in the display)?
If not, please do so and re-submit the correct serial number.
Please help me 99 Boxster
Becker - w5005135 serial number
CR220
I’ll absolutely donate !!!
my battery died today and I was stuck on the side of the road . Good now after roadside came out and replaced the batter but I have a 4 hour drive with no radio 😞
Edited by Sky Borg
CR220
Try 0634
Hi Loren, I had pulled the radio to get it off the label.  I did try the Lost Radio Code FAQ procedure (thank you, that is much easier than pulling the unit).  The procedure did yield the same serial number as the label (thankfully).  So long story short, I tried the 4702 code again and for some reason it took it on the first try today...everything works.  Thank you, thank you thank you.
