Just changed my battery and lost the code
Type 4362
Ser Y5021866
not sure what this is 24/99
Can you help?
Thanks!!
Howard
Try 0563
or
0561
Neither one worked.
Any other choices?
I assume I just have to type them in when it prompts me?
Howard
Please read this and follow the instructions...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
I just bought a 1990 944 S2. It has an original Porsche CD-2 stereo, but I believe I need the code to make the stereo work. I removed the stereo to look for a code somewhere on the mounting bracket in the dash.....no luck. The stereo has a sticker on top that says "remanufacture unit". Is there any way for me to get the reset code? It would still be tied to the VIN, wouldn't it?
Car VIN: WP0CB294XLN480886
Stereo S/N: PO CD-2 W 09 10272
Then it has another set of numbers beneath it
B 8 09 10272
Thanks in advance for any advice you can offer.
Regards,
Ian Rainey
678-362-7453
B 8 09 10272
Regards,
Ian Rainey
678-362-7453
Do you know if this is a Blaupunkt or Beckjer radio?
Also, how many digits in the code?
Are you sure the serial number doesn't start with BP instead of B8?
Not enough digits in the serial number for any of my Blaupunkt decoders.
Where would we be without this website?
Y5054322
Thanks...
Try 3072
or
3070
Thanks for the amazingly quick response, however it didn't do the trick! Rats!!
Here is all the info from the unit:
CDR 220 Becker1 Type 4462 Y5054322 24/99
Thanks...
Y5054322
Thanks...
Try 3072
or
3070
Thanks...
Please help anyone
2001 996 Turbo
CDR220
BE 4462
Serial: Y5054555
Lauren, did I do that right?
Edwin
Try 9272
or
9270
Thanks for the quick response Loren. I plugged the radio back in and turned it on and it showed "Wait" and didn't allow me to input the code. Anyone know what this means? The wait message never changed
EDIT: NVM... it means the radio has locked me out. I'll try again in an hour
Edwin
Edited by m32
Please help anyone
2001 996 Turbo
CDR220
BE 4462
Serial: Y5054555
Edwin
Try 9272
or
9270
Edwin
i got a 2000 boxster s and the radio is locked its a cdr 220
Becker 1
Type 4462
SN:x5038404
Any help would be greatly appreciated
thanks
Try 3472
or
3470
neither of the codes worked for me,i also tried 3471 with no luck, any other suggestions?
matt
Becker 1
Type 4462
SN:x5038404
thanks
Try 3472
or
3470
matt
I have a 1997 Porsche Boxster with the radio unit CR-210 when I purchased the car it had a after market radio, but I want to put back in the stock radio however I do not have the code.
Here is the info on the sticker located on the radio.
(Barcode)
*2182L 0T5003541*
993.645.117.01
EC: 100
Model-No.
BE-2182
Serial-No.
T5003541
Thank you for all your help.
Aaron
(Barcode)
*2182L 0T5003541*
993.645.117.01
EC: 100
Model-No.
BE-2182
Serial-No.
T5003541
Aaron
Try 8846
or
8844
