997.1 Window Drop (Passenger)
Stock 2007 C2 63k miles.  Passenger window will crack 1/4" with inside/outside door handles and stay open after they are released. but will not return full up once the door is closed.  I have to run the window up manually after closing the door and get out drivers side (which works fine).
I have read lots of threads about the regulator and threads with the opposite condition (window goes up while door open).
pull inside handle slightly, (without opening/release the door) drops
release inside handle flat/push on it, no movement/stays drop
^same condition with the exterior handle, microswitch drops window, never returns it.
drivers door  works as intended inside and out.
both doors closed,  car locks clean (no beep) window still stays cracked.
One-touch:
Noticed drivers window one-touch up->down works fine.  Passenger side down works, up does not (not even after 1/2 way).  Tried a few different reset procedures I have found, still does not work in the up direction at all.
I am wondering if the door-open drop function 'uses one-touch' to perform that action..drivers one-touch works up/down and window drop works.  pass side one-touch only works down and window drop only works down.
