Porsche 996 2002 C2 Cabrio Windows only go up when top is down
Just replaced the battery a day ago and started working on the drivers seat which has been inoperable since my daughter was driving the car and she moved the seat forward.  I was able to remove the lower portion of the seat to inspect and diagnose but havn't been able to fix.  While I was working on the seat I put down the top.  When the top is down the front windows go up if I hold down the top button till the are up.  Then I go to put the top up and the top goes up properly but when it closes,  it used to put all the windows up,  now the top latch opens and closes like it doesn't know that the latch is closed properly.  None of the window switches will do anything,  and when i put the key in the door and turn to close the windows nothing happens.  I also unplugged the alarm box under the seat and plugged it back in again and that didnt help help help!
