I'm trying to smog my '14 991, but I have one sensor that is not in the ready yet, the o2 sensor.  I've driven the car over 1k miles now, and have tried the various drive cycles that are out there (anyone realize how dangerous it is to drive 54mph on the freeway!?  this is at the butt crack of dawn too!)
A local p-car enthusiast has indicated I could utilize his PIWIS to help with this issue.  Does anyone know what screen I need to get into force a 'short test' that I've seen mentioned on the interwebs?
Thx!
@Loren Any other suggestions besides driving it?  I've put 1k miles on it, and still can't get the o2 to be ready.  I called the dealer and they want $500 to get it ready -- seems a bit excessive.  My understanding is they can run some sort of short test to get it ready (but I may be wrong here.)
Are you sure that the sensor in question is working properly?  An intermittent fault can cause the system to not reset.
As JFP said an intermittent sensor or other fault can cause the not ready state. .
Hmm, how do I check if there's an intermittent fault?  I don't see any codes that are stored (using a iCarSoft device).  And when I look at each of the o2 sensors individually, they're all showing "pass" and within the range.
Usually, intermittent faults are stored as "pending codes", although O2 sensor codes can clear themselves if the DME sees the system going back to normal activities. As I do not know how your tool handles that, I cannot specifically say where you may find them.   I would be looking at how the sensors are performing from a voltage standpoint, both sensor on either side is expected to remain within certain limits, of one of them is occasionally wander outside those limits, it can delay the reset, but that would need to be captured in real time.  Intermittant faults are always the hardest to nail down.
Okay, got an update.  Plugged in the PIWIS and low and behold, it shows the o2 sensor as ready.  Further digging shows that the "VarioCam PLUS" status as a "sad face"
I also see a fault in memory, P2271, "o2 sensor signal biased/stuck rich, bank 1 sensor 2 (Limit exceeded)"
Any ideas here?
Thx
The causes for this DTC may include:
*Contaminated or failed HO2S2 (Sensor 2)
*HO2S2 wiring/circuit problem
*Fuel pressure incorrect
*Faulty fuel injector
*Engine coolant leak
*Faulty purge solenoid valve
