Hey guys,
My 996, a late 98 3.4, started to exhibit a strong knocking sound coming from the driver's side of the engine. It's the dreaded "sounds like a lifter" type of knock. Very audible at idle, gets faster & louder as revs increase (haven't revved it past 2.5k):
STREAMABLE.COM
Watch this video on Streamable.
STREAMABLE.COM
I did push the car fairly hard a few hours earlier, though for a very short period of time (basically merged from 40-150+ and backed off, engine fully warmed up). No overheating or oil pressure issues. The car was running fine coming home, I have a small garage so I would have heard anything backing up with the windows down and the sunroof open. Started it up three hours later, and the noise appeared within 500 yards. I didn't do anything to the car in between save for a mod on the PSE relay (cutout delete), which seems unrelated.
Also, the car just spent 3 weeks in the shop for a new IMS / clutch, and cylinder #6 was bore checked, with no evidence of scoring found. One of the chain tensioners was also swapped for a good used unit. The oil is brand new (<150 miles), the oil level hasn't changed, and oil pressure is still good (4.5 bar cold). There also isn't a single code on the ECU.
The tailpipes are a bit black on the inside but there's no oily residue in them, nor is there any on the bumper. Overall, this is a very clean car with a full service history, low miles (45k), and "only" four prior owners in 25 years, though it was seldom driven in the past 10 years (6000 miles or so).
I didn't have it towed yet but showed a video of it to a couple of shops, both of which were sort of expecting a full rebuild would be needed. Interestingly, one said he found most cases of catastrophic engine failures he sees happen within weeks / months of a car changing hands.
In any case, I'm looking for any kind of input / help, but will also accept empathy and Porsche reliability jokes.
BR,
Edited by Achlex
Hey everyone,
Issue turned out to be a collapsted lifter. It went right back up after an oil change. No debris in the filter.
I will keep a close eye on how it runs in the coming months!
