Thanks my internet is down, I'm trying to do this on my cell phone. I guess I will wait the hour until I try the codes you suggest. Thanks.
I also did not get the code card with my used Porsche and the battery went dead over winter. Next year battery maintainer! Any help would be appreciated. It is a 2000 Carrera
CDR-220
Type: 4462
Ser: y5040879
24/99
Thanks.
Try 0857
or
0855
Tried 0855, 0857, 0856 and 0858 none of them worked but I will cycle through them a couple of times to be sure....... lots of waiting.
Thanks for the effort.
  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
It seems like you get 3 chances before it goes into that wait for an hour mode. If you turn the radio off and on after your 2nd attempt after a 5 minute pause it will allow you another shot without having the long wait.
Edited by perfectlap
Hi Loren, it's a same for me, radio code problem
Type CDR 210
serial no. 5016749
Tanks
Andre
Try 4845
0r
4843
[/i try 4845,4843,41,39,47,49,51. It doesn't work. You have a suggestion, Tanks Andre
Loren,
Need radio code. (duh, why else would I post here?)
CR-220
BE6624
15000109
EC: 101
Perry
Try 4456
or
4454
Loren,
Interestingly enough, my dealer will give you the code, over the phone, with just your vin and the serial #, if it is not the original radio! For FREE!....Turns oout the correct code is 5456...you had given me 4456..too close to be a coincidence..maybe if the 5% doesn't work, try the first number up or down 1???? Thought you'd be interested. Thanks
CDR-220
Type: 4462
Ser: y5040879
24/99
Thanks.
Try 0857
or
0855
0859 worked Thanks.
CDR-220
Type: 4462
Ser: y5040879
24/99
Thanks.
Try 0857
or
0855
0859 worked Thanks.
Hi
Iam from germany...i bring a boxter from miami to Munich(Germany9 but i lost the CODE from the Radio
Model CR 210
Art. R3297
SerN. V5008018
Please HELP ME......Thank you greeting from Germany...sorry my english is not sooooo good.
CDR-220
Type: 4462
Ser: y5040879
24/99
Thanks.
Try 0857
or
0855
0859 worked Thanks.
Hi
Model CR 210
Art. R3297
SerN. V5008018
Try 1143
or
1141
Greetings! I seem to have the same issue- my battery went dead and I lost my radio. I followed your instructions to find these numbers- thank you SOOOO much!
'97 boxster
5-speed
radio style CR 210
model R1996
serial #Y5001844
Thank you again much for your help.... I miss having tunes!
Aloha...
Edited by surs
'97 boxster
5-speed
radio style CR 210
model R1996
serial #Y5001844
Aloha...
Try 6803
or
6801
Help Please! Same problem, lost radio code.
1997 993tt.
model #: R1996
serial #: T5002722
Thank You in advance for your help,
Len
1997 993tt.
model #: R1996
serial #: T5002722
Len
Is the a CR-21 or CR22?
I have no idea if this will work for your radio...
Try 8469
or
8467
It's a CR 210
8469 or 8467 did not work.
1997 993tt.
model #: R1996
serial #: T5002722
Len
Try 8469
or
8467
1997 993tt
Radio CR-210
Model #: R1996
Serial #: T5002722
I've read the FAQ and I think I've done everything right. I'm trying to get my dealer to help but still no luck.
Can you try again, PLEASE!
Sorry to be a pain,
Len
1997 993tt
Radio CR-210
Model #: R1996
Serial #: T5002722
Sorry to be a pain,
Len
Try 8469
or
8467
'97 boxster
5-speed
radio style CR 210
model R1996
serial #Y5001844
Aloha...
Thanks Loren. Unfortunately the numbers aren't working. I got the "code" sign, pressed the number in, then pressed the "up" arrow... and nothing..... just the "code" sign again. Any other words of wisdom?
I appreciate your help so much. It's amazing how many people you've saved from car-silence!!! =)
