  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Boxster 2.5L
UMM? Its a manuel transmission its a ==== 5speed + Reverse, so whats that, Sorry :huh:
TAN
US
:) THANK YOU.
I need your radio serial number.
Please read this and follow the instructions...
Thanks for responding
Becker 1
4462
48/98
X5020732
Thank You. :)
Try 2513
or
2511
Boxster 2.5L
TAN
US
:) THANK YOU.
Becker 1
4462
48/98
X5020732
Thank You. :)
Try 2513
or
2511
Thank You, :D
Please tell me how much i owe you, Thank You, I appreciate it.
-What other types of Codes are You able to get, such a key programming, or specifications such as how to program a key remote alram, Thank You :)
Boxster 2.5L
TAN
US
:) THANK YOU.
Becker 1
4462
48/98
X5020732
Thank You. :)
Try 2513
or
2511
Thank You, :D
I entered the 1st number, it went back to code.
i entered the 2nd number, but i think the last number wasnt pressed correctly and it went back on code.
The third time i re-enterd 2511 and the "WAIT" message is displayed, any Ideas
Thank You!! :huh:
Hi
I have a 1999 Carrera with a "CDR 210" Ser # w5018912 .
I change the battery and do not have the code for the radio.
Any help with the 4 digit code would be appreciated.
Thanks David Collins
Boxster 2.5L
TAN
US
:) THANK YOU.
Becker 1
4462
48/98
X5020732
Thank You. :)
Try 2513
or
2511
Thank You, :D
Key program codes (IPAS codes) must be obtained from an Authorized Porsche dealer/OPC. Then you need to protect hem because anyone in possession of those codes could program a key and steal your car.
Boxster 2.5L
TAN
US
:) THANK YOU.
Becker 1
4462
48/98
X5020732
Thank You. :)
Try 2513
or
2511
Thank You, :D
Thank You!! :huh:
READ the FAQ.
Sorry, I just figured out where to post this request
2001 911 Cabriolet
6spd, Black on Black
Radio Type CDR220 (4462)
Serial # 15061937
Thanks in advance,
Chris
Thanks for this awesome forum, it's a huge help. I have a 2001 Boxster, 2.7L H6, 5 Spd. I just changed the batter and discovered that none of the original materials has a radio code. Here is the type and serial number:
SER# Y5045220
Type is 4462
Thank you so much for your help!!!
Best regards,
Mark
SER# Y5045220
Type is 4462
Best regards,
Mark
Try 4898
or
4696
2001 911 Cabriolet
Serial # 15061937
Thanks in advance,
Chris
Try 4715
or
4713
Hi again,
I have tried both codes, either do not work, any ideas??? Thanks
Yes. READ the FAQ.
Hello,
I had a dead battery on my 1998 Boxster. I bought it used and do not have the radio code.
1998 Porsche Boxster 2.5
5 Speed
US model
Becker CR-210
Model R1996
serial # V5005255
Thanks for your help!
Hi, I hope someone can help. I have lost the radio code. this is the info I have found. I'm not sure how to go about getting it. Any help would be appreciated.
Becker 1
type 4467
seri 15003447
24/99
Thanks John
