Need porsche boxster radio code
Make: Becker
Serial Number: W5007885
Type:4362
30/98
GAL:00
That's all the numbers that came up when I held the TP button down for 10 seconds and twisted the knob
Thanks for any help that is provided!
-Jason
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Make: Becker
Type:4362
30/98
GAL:00
-Jason
Try 2912
Also the type is 4462
You mis-typed the serial number in your post above.
The correct code should be: 2585
Thanks so much -so focused on the numbers forgot the back slash - Thank you I'm very grateful.
Hi there,
 I've lost my code too. Any help would be greatly appreciated.
Becker CDR220
Serial No: Y5024115
Type: 4467
Cheers
Hi there,
Becker CDR220
Serial No: Y5024115
Type: 4467
Cheers
Try 0764
Make: Becker
Type:4362
30/98
GAL:00
Thank
Make: Becker
Type:4362
30/98
GAL:00
-Jason
Try 2912
thanks so much! code worked first time like a charm!
-Jason
worked
I need codes for 1999 Boxster
Becker 1
Type 4462
Serial:X5020053
48/98
CDP2081
thanks
Edited by jassmix
Hi there,
Becker CDR220
Serial No: Y5024115
Type: 4467
Cheers
Try 0764
I have music again!
Cheers Loren
I have lost the code for the Becker CDR 220 radio in my 996 Carrera 4S. The radio serial # is 25007171. Thanks in advance for any help. Tom
I am not sure why you felt you needed to post this twice...
Try 0542
I bought pre-owned 2001 Boxster S with no codes.  Had battery problems and replaced it.  Battery disconnect killed radio.  Used TP button procedure as described here 7 yrs ago and here are the required
numbers:  Becker 1,  Type 4462, Seri 1561531 24/99.
In using the TP button procedure there was 3 other categories that I'm not sure of: GAL 1   00,
AUX   OFF (with up and down arrows under the word OFF),  CD  CDP2081.  Would appreciate being clued in on the last 3 items in addition to the radio code. THANKS--
Try 9148
Could you please provide me with a radio code for a 2001 Boxster S.
Radio: CR-220
SN: 15040514
Type: 4362
Thank you for what you do!
Radio: CR-220
SN: 15040514
Type: 4362
Try 1017
Radio: CR-220
SN: 15040514
Type: 4362
Try 1017
Perfect!  Thank you so much!
Loren, thanks for the timely and accurate reply dispite having entered the radio serial no. incorrectly!
Thanks again for all you do----speedy
